REQ: Vol pot id and source to buy
Started by Om_Audio, June 17, 2014, 09:42:41 PM
Om_Audio
Need to replace this vol pot on my Roland SP-404SX but cannot id it and find a place to buy-
any help appreciated-
Sent via soup cans and string.
rullywowr
Looks to be a 9mm 50kB alps brand.  You can tell because of the "503B".  50 + (three zeros) = 50,000 ohm.  B means linear.  I see that mouser has some alps but not with the other two pins which seem to hold the pot more securely.  You should be able to use a regular 9mm 50kB pot in its place.
http://www.mouser.com/ALPS/Passive-Components/Potentiometers-Trimmers-Rheostats/Potentiometers/_/N-9q0yp?P=1z0zlgmZ1yzvm30Z1yzmno6
haveyouseenhim
The two extra pins could be a switch.
I'm sorry sir, we only have the regular ohms
Om_Audio
Quote from: haveyouseenhim on June 17, 2014, 09:58:51 PM
Nope- it is a simple non-detented volume pot- no switch.
C
RobA
It looks to me like there are traces to those outer pins.
I found these on the ALPS site, but they don't list any as 50kB in this configuration. They look like the same type of pot though. Maybe Roland had the 50kB's made custom for them.
http://www.alps.com/WebObjects/catalog.woa/E/HTML/Potentiometer/RotaryPotentiometers/RK09K/RK09K12C0A8P.html
Affiliations: Music Unfolding (musicunfolding.com), software based effects and Rockā€¢it Frog (rock.it-frog.com), DIY effects (coming soon).
