Bax30 - HV Content - Clip!
Started by GrindCustoms, June 15, 2014, 02:23:41 AM
GrindCustoms
Hi guys, here's another twin tube pedal based on the schem by Marauder/Juansolo.
It's the input/gain stage of a VoxAC30 sandwiched between 12AU7 buffers (cathode follower) at the input and output of gain stage that then goes into a 2Band Baxandall Eq.
I had previously built the lower voltage single tube version of this, this one for the moment is less gainier, kind of a mild OD with LOTS of tones shaping ability and a SHITONS of output. ;D
This one can be used as a drive pedal in front of an amp and it sounds amazing.
Picstory of the Bax30:
Enclosure layout, this time i've thinkered a little bit more about the input/output jacks and DC Jack, works better this way.
Ground bus done and a bit of wiring.
Most of the gain stage wiring is done, used some Mullard and Mustad for added mojo!  ;)
Baxandall hook up complete, i used standard pedal caps here for real estate matter.
Input Buffer stage done.
Output buffer done as all the tube related stuff.
This is the 12AU7 used for this built, on top of sounding great, it looks damn cool!
The Final!
Shielded wire used for all the ins and outs.
Soundclip will happen some time tomorrow!
Rej
Bax30 Crap Clip!
Vox AC30 input stage with Input/Output tube buffer with Baxandall 2Band Eq
Gain stage tube: Brimar 6BR7
In/Out buffer tube: RTT 12AU7
Guitar: Schecter Tempest Custom w/Suhr Aldrich Humbuckers, both pickup position. Tuned 2 whole step lower.
Signal chain:
Guitar --» Klonish Buffer --» GCFX RottenKomp --» GCFX Catch22 OD --» Bax30 --» Decimator (filtering, no gating) --» Mesa Mark IV Clean Channel --» FX Loop (Ibanez AD9 --» RaD DLX Reverb) --» iPhone w/Tascam iM2
Wower! What a beast. Can't wait to hear it.
that may be one of the coolest things I have ever seen  :o
stecykmi
Rej, you are a certified badass...and a lunatic. Can't wait to hear this thing.
GrindCustoms
Thanks guys, repeating myself here, but these are so much fun to put together.
Having a PCB for these will be great, but.... PTP is rewarding, give it a try! ;)
MarcFive
What, no effects loop? :) Sheesh. That's freaking awesome. Can't wait to hear it.
sonarchotic
Quote from: lincolnic on June 15, 2014, 03:38:11 AM
+1
Amazing looking project!
marauder
Can't believe you finished it before we did!
Love seeing others build process/work, thanks for sharing!
Great looking pedal!
Cortexturizer
Man, your pumping out awesomeness in bunches...! Any chance of putting the schematics for your projects up and even dreaming of fabbed boards for these.... :o
GrindCustoms
Thanks again guys!
Quote from: cooder on June 15, 2014, 06:57:30 PM
These circuits other than the 1W power amp i did are made from the schematic made by Juansolo and Marauder you can find them in the tube section of their website.
But YES! PCB layouts are in the work for these circuits and PSU wich will be offered as a full kit (couple non-common parts, will be easier that way).
Marauder is actually working on another preamp circuit and if time allows, i'll probably have more work done on the Fender VibroKing that i've been lurking at the whole last week.
The whole tube thing is taking me over... we're far from seeing the end of all this! ;)
Quote from: marauder on June 15, 2014, 05:09:53 PM
Now you know that you must not send me the schem before you have yours boxed! :P
Thanks for the hardwork and help bro! 8)
Quote from: MarcFive on June 15, 2014, 08:25:42 AM
Hmmm.... i think i don't get it...., would you put an effect loop in a TubeScreamer? :o
Quote from: GrindCustoms on June 15, 2014, 07:26:18 PM
Not quite, I haven't taken Cleggy's hand drawn stuff and made it pretty yet ;) It'll be up after ours is put together (later this week). Working from them at the mo.
