Perfect tone transfer with magazine paper
Started by Gledison, June 05, 2014, 06:52:51 PM
Gledison
Quote from: Hangingmonkey on June 05, 2014, 08:59:14 PM
Wow, is that all.  Maybe I'm overdoing it, I don't go any less than 4-5mins and that's using pnp (and my etches suck)
As Cody mentioned, you have to find what will work for you. i've tried adhesive backing paper, which work for some people but not for me.
There are so many variables like toner quality, paper, temperature, print quality, pressure, etc..
im not much experienced on that, but i think i found a methode that is working for me. I was following some explanations from other folks, and one thing i've seen a lot was to use the iron at the maximum temperature. I took it for granted, and never worked for me. By using at max temp, my tracks kind of melt down causing a blur on the transfer. i was reducing the temperature slowly, till i found out that on the Slik mode, i got the best transfer...
keep trying, change one variable per time and you will get it for sure!!!
Cheers
