Affordable tweed champ clones?
Started by Jmilla, June 05, 2014, 05:00:50 AM
Jmilla
Are there any out there under 500 built that are fairly well built?
oldhousescott
How handy are you with an iron, and how comfortable are you working with high voltages? Weber has a Champ kit for under $500. When they first starting shipping kits, years ago, some of the parts were a bit sketchy, but the new kits use all good quality stuff.
Jmilla
Im ok wth an iron but the voltages scare the bajeezus out of me.
atreidesheir
You can easily get a silverface Fender for less than that.  There are simple mods to make it a tweed.  But it sounds awesome stock.
miter53
I've built a 5E3 and a Firefly for myself, and I do careful and pro quality work. There's a thread around here with pics of the Firefly. I can build a Champ from the kit of your choice for $100. Mojotone has a good one for just under $500 that includes chassis, transformers, tubes, speaker and tweed case. Boot Hill has excellent kits also. PM me if you have any interest.
The amp on Reverb looks like a hell of a deal btw.
Good luck!
Mike
"Only sick music makes money today."-Friedrich Nietzsche
My photography website: http://michaelteresko.com/
thesameage
How is the firefly? From what I've read, it's hard to get a good, clean tone out of it. True or not?
miter53
It definitely leans towards growl over clean. With the boost switch off, and the volume not cranked too high, you can get some nice cleans, but it really shines overdriven.
pryde
Dave at Boothill Amps might build you one for close to that price. He sells complete 5E3's for ~$850. Should give him a message.
However, I think you should build the kit yourself. If you can build pedals you can build the 5F1. Just have to obey the safety rules and you will be fine.  :)
miter53
And it's refreshing to work inside a box that is bigger than 3" x 4"! As long as you follow some simple safety procedures, there's no danger. The biggest risk is to your wallet; building amps is pretty addictive. I'm thinking of an Allen Brown Sugar next...
Jmilla
Do you fellas have any tips for safety with this stuff? I kinda want to try building one now.
pryde
Quote from: Jmilla on June 06, 2014, 12:19:15 AM
Here is a good start for you:
http://www.aikenamps.com/index.php/safety-tips-for-working-on-tube-amplifiers
oldhousescott
Paul Ruby has some good links for a safe build (Aiken's is one of the links).
http://www.paulrubyamps.com/info.html
And here's a good overview of putting a small single ended amp together starting from scratch.
http://www.ax84.com/static/p1/AX84_SE_Builders_Guide.pdf
The Firefly is pretty much a one trick pony, if it's not loudly ripping your face off it's not on. For the cost of the iron necessary for a Firefly you could get the iron for a nice versatile SE 6v6 build that would work well with all the Madbean projects you've been putting together.
Have fun... another addiction to manage!
miter53
