Function FX Duovibe
Started by Morgan, June 04, 2014, 04:55:41 PM
Morgan
I scored this sweet Basic Audio enclosure from a fellow forumite a while back (michaelballard maybe?) and have been saving it for a special build. I could think of no other circuit more worthy than the Duovibe designed by my good buddy, the Funky Jesus!  :D (plus, I am a total, filthy vibrato whore... :o)
Awesome circuit, LOVE the vibrato mode. 1590B enclosure with top mounted jacks; It's going right on the pedal board. I'd really like to see a 4-stage version of this!
Also - thanks a bunch to Rej for sending me the LDRs. They work great!  8)
A note on the cloth wiring - I don't use that stuff to be fancy. When I started monkeying with electronics, it was refurbishing vintage amps. The I started building amps, then finally I started building pedals. I got used to the cloth wiring in old amps and just keep using it because I like not stripping wires and it has never let me down.
Had to grind down the lip on the inside of the enclosure lid because of the top mounted 1/4" jacks - 5 min on the grinder and no problems.
Moderator at BYOC, still sometimes futz around with Leila Vintage Electronics.
Old Blog...
wow, great build. The enclosure looks awesome, the colours fit very nicely together.
What kind of funky wires are those?
Cloth covered wires are DROP DEAD SEXY!!!
Wish I could find a good deal on some  :-X
icecycle66
Cloth covered wired keep the electrons warm creating an inversly cool vibe.
Very nicely done with the wiring and artwork. Super clean looking. What pots did you end up using on your build? I still have a non working one on my bench that I need to spend some more time with.
Great build, Morgan!
Glad you like it.  :)
Very nice!  Maybe I can get my wife to knit me some wire, too.   ;D
GrindCustoms
That's really nice Morgan, glad the LDR worked out.
Where do you get those «bezel» mounted DC Jack?
muddyfox
It seems to me that you got the knobs from Rej as well!  ;D
Morgan
Thanks 'erbody!  ;D
Quote from: selfdestroyer on June 04, 2014, 06:17:57 PMWhat pots did you end up using on your build?
The stock ones listed in the schematic. Am I supposed to play with the values? Wouldn't mind a touch more depth.
Old Blog...
Morgan
Quote from: GrindCustoms on June 04, 2014, 07:32:19 PMWhere do you get those «bezel» mounted DC Jack?
That is one of these: http://www.mouser.com/Search/ProductDetail.aspx?R=163-1060-EXvirtualkey11180000virtualkey163-1060-EX
I actually think that I like the smaller ones from BLMS a bit better though.
Quote from: muddyfox on June 04, 2014, 07:44:40 PMIt seems to me that you got the knobs from Rej as well!  ;D
LOL! I couldn't resist roughing them up a bit. They were just too shiny! You should see the copper ones - they REALLY look like Rej got to 'em.
http://buildyourownclone.com/parts/knobs/1510-style-knob.html
Old Blog...
GrindCustoms
Quote from: Morgan on June 04, 2014, 10:32:31 PM
Thanks for the link, i was actually putting another Mouser order together, will give them a try.
Have you purchased some of the Lumberg style from Lawrence lately? I had bought some when he first had them in stock, the fit was not good enough so i commit stashing up with that offering.
Morgan
Yes, I got some in from Lawrence 2 weeks ago. The fit is good as far as the nut and thread. The jack grip is pretty tight, but so are the kobiconn ones.
Was there a specific issue you had?
Old Blog...
GrindCustoms
The center tip had the tendency to have a diameter a tad more than 2.1mm and would severly gripe into the power patch cable, at a point where it would fit in and when removing the power cable the center pin would follow. GuitarBen also had that issue.
