Vibe switch on Pork Barrel
Started by sjaustin, June 03, 2014, 01:37:46 PM
sjaustin
Hey all, is there a simple way to put a vibe mod on a toggle switch on the current version (2011) of the Pork Barrel?
Lift R9 -- that will disconnect the dry path.
sjaustin
Thanks. So would it work to get a DPDT switch, install R9 across lugs 1 and 4, and then connect 2 and 5 to R9's spot on the PCB?
sjaustin
Bump—am I on the right track here?
Your way is fine, but you only need a single pole switch.
1
2
3
1: PCB connection #1 (doesn't matter which pad)
2: Wire + resistor connected to PCB connection #2
or if you don't want a resistor floating in space
1: one side of the resistor + PCB connection #1
2: Other side of the resistor
3: PCB connection #2
sjaustin
