TL022 Substitute?
Started by peAk, May 31, 2014, 03:43:46 PM
So I was finishing up my Flying Pan build and I noticed that the 5 ICs it calls out for are TL022.
I purchased the components for this build months back and I believe I ordered substitutes for these per Steve's (Smallbear) advice. Now I just can't remember what they were.
Would it have been TL072, 3080 or 4558? Possibly something else?
Any help would be greatly appreciated!
TL062 would be the ideal candidate for a sub.
They still make TL022s I believe so you can probably get them.
The TL072s "should" work.  ;)
Quote from: Govmnt_Lacky on May 31, 2014, 03:55:21 PM
I just wanted to fire it up today  :'(
You can use the 072s. It will probably work just fine. I meant to say that they are not the closest sub but, they should be close enough for this project.
Quote from: Govmnt_Lacky on May 31, 2014, 04:04:48 PM
no, I appreciate the help. I only have 1 TL062.
I have many of the others I mentioned. I might try the TL072.
What's the worst that can happen? Just not work or not work right?
I don't think you are in danger of it not working at all with the 072s. That being said, I am not familiar with the Flying Pan but, if it has an LFO section, then the 072 may not work as it is not a low-current dual op amp.
If it does have an LFO section AND the 072s do not work there, you could try swapping just the LFO amp with a 062 or even an LM358.
Mouser has ~3600 in stock, you'd no doubt get them pretty quick. http://octopart.com/partsearch#!?q=tl022
Thanks for the help guys
I am going to go ahead and grab some from mouser like you mentioned. I tested the circuit with TL072 and the 4558 and everything works but the phaser portion wasn't phasing quite right no matter how I adjusted the trims. It had phase, just not right. The tremolo portion worked fine.
Mouser gets to me in a day so it's not a huge deal.
again, thanks for the help!
