Problem Yellow Shark PCB
Started by memor82, May 31, 2014, 03:23:56 PM
memor82
Hi!
I've just got a problem with a Yellow Shark.
All pcb's holes was been hard to solder and a piece of link just jump of the board  :(
What can I do?
Thank you
memor82
Anyone?
Inviato dal mio Galaxy Nexus utilizzando Tapatalk
muddyfox
#2
It's weekend man, patience!  ;D
So, from what I gather, you lost the connection between round (cathode) LED pad and switch wire?
memor82
Sorry :-)
This is the single sided version.
I lost Sw and catode (circle)led pad
Thank you
muddyfox
#4
Run a wire from square LED pad to offboard LED anode and another wire from LED cathode to switch, that's all.
memor82
Ok I'll try!
Thank you so much.
Good weekend man
muddyfox
That's gonna work for sure, what you lost does nothing more than give you nice labeled pads. It's a connection from LED cathode to wire which you can skip altogether since the LED is offboard anyways.
memor82
understood.there's always something to learn :-)
Thank you man
muddyfox
No problem! Let us know when you sort it out!
memor82
Sorry man,
but I think that this pcb is faulty.
Now has jump off the "out" pad  :'(
They letterally came off from the pcb
muddyfox
No problem, just solder it anywhere on the track leading from the missing pad. Hole is not really necessary if the wires are not under stress.
memor82
Ok thanks!
Your iron might be too hot, also try to make the time you're on a pad with your iron less than 6 sec
irmcdermott
I agree that your iron may  be too hot if you are lifting traces and pads that easily/quickly.
memor82
Quote from: irmcdermott on June 01, 2014, 02:45:38 PM
310 °c, few seconds
Already assembled Pork Barrel and a Retrograde and many other pedals from musikding and tagboard with no problem.
60/40 Solder
