Designing my own Kingslayer 2 PCB
Started by AlejandroRivera, May 29, 2014, 01:21:32 AM
AlejandroRivera
I want to design my own Kingslayer 2 PCB, but instead of using 1 quad op amp, I want to use 2 dual op amps, so I can experiment with different models
Do I need to change the power supply provided in the schematic? Or it will work using two dual opamps instead of 1 quad?
thanks!
rullywowr
It will work just fine. Each opamp will be connected to where the 074 gets power.
AlejandroRivera
Thanks, rullywowr! I'll post my PCB as soon as is finished
sdlogan9
Sounds cool!!  I will be interested to give it a try!!
I really like the Kingslayer.
