how to fix pcb on enclosure
Started by copachino, May 23, 2014, 04:34:27 PM
copachino
hi, i have seen many of you that dont use on board pots, but, somehow on the photos, the pcb looks fixed, i have a project that always give issues, the pcb always move around, and some times the fx stop working because come cap shot a pot, or something happens, there, but its a pain in the ass, what can i do to fix my pcb??
Morgan
  This stuff works great. Just coat the back of the pcb with it and stick it to the back of the pots or the enclosure.
http://www.amazon.com/Scotch-Exterior-Mounting-1-Inch-60-Inch/dp/B00004Z4BV
Moderator at BYOC, still sometimes futz around with Leila Vintage Electronics.
Old Blog...
copachino
i got some of that, i have never tried it before for pedals jeje, i use it to put small mirrors, i will see its that work fine for me then jejeje thanks, i think many of you hate me for posting everytime such a noobs things... sorry for that
Yes, I can confirm the double-sided tape works quite well.
GermanCdn
+1 for double sided tape.
Adhesive back velcro would also work, and gives you the added advantage of being able to reposition it.
I like aluminum standoffs JB Welded to the enclosure so my layouts have space for the standoffs. Otherwise 3M double sided tape for auto trim.
rullywowr
I try not to use tape when I can, but sometimes it can't be avoided.  The 3M tape works great.  I have also used these in the past with good results (Self Adhesive PCB Standoffs):
Yep, 3M VHB is highly  recommended if you have to use double sided tape.
They have different formulations to match various substrates.  McMaster Carr has a large selection of it.
copachino
in favt i have the 3M double sided tape, im gonna try when i get home
Quote from: copachino on May 23, 2014, 04:51:40 PM
As long as you're willing to learn, people here are willing to help you learn :)
Plus there tends to be, for every poster, a bunch more lurkers with the same problem.
Quote from: alanp on May 23, 2014, 07:31:38 PM
Agreed.  We all had to start somewhere.
