Can't find B2M pots for my Sharkfin
Started by das234, May 10, 2014, 07:24:50 PM
das234
Anybody know where to get B2M PCB mount pots for the Sharkfin?  I haven't found any yet.  Or should I make one out of a B1M and a resistor?
stecykmi
#1
1Meg pot + 1Meg resistor will work if you don't want high resonance settings since the minimum resistance would still be 1Meg. otherwise, 5Meg pot with a ~3Meg resistor in parallel will work. or you could do the 1Meg pot with a switchable series 1Meg resistor for a HI/LO res switch.
but i'm also curious where 2Meg pots can be obtained...
I *think* I got 2M pots from Smallbear for my pll -- solder lug, so I used wire clippings to mount 'em.
RobA
#3
I've never seen a B2M. You could use a dual gang B1M and wire the gangs in series.
Edit: Just checked and Smallbear does have lugged B2M 16mm pots.
Affiliations: Music Unfolding (musicunfolding.com), software based effects and Rockā€¢it Frog (rock.it-frog.com), DIY effects (coming soon).
das234
Good enough.  I'll make my own PCB mount.  Thanks
