Final version of Lovetone Doppelganger clone
Started by LaceSensor, May 10, 2014, 11:32:18 AM
Finally got round to verifying the 2.1d boards
Had the case drilled for months! Just time. I can now order these, as Jacob (JMK) did the gerbers for me ages ago :)
Sounds and functions perfectly, and now the wiring is much neater and the silkscreen is perfect, thanks Jacob.
Ridiculously impressive. That's a real feat.
slimtriggers
Guitafuzz
Awesome Build!!  What type of enclosure is that?
awesome, cool to see someone using the anchor tabs on the pots
Quote from: Guitafuzz on May 13, 2014, 04:19:29 PM
1790ns size
its a hammond 1590XX
142 x 120 x 40 mm
soggybag
Which pots and toggle switches did you use? I'm working on one of the boards right now, and I'm wondering about the heights of these since they are board mounted.
I finished mine late yesterday night (be ready for the build report) and I used 9mm pots (the ones with the hooks on the side to go through the bigger holes in the pcb) and regular switches like these. At first I had some problems with small height differences, but taking the first nut of the switches solved it.
Quote from: soggybag on August 17, 2014, 07:04:34 AM
9mm pots by alpha
Tayda/Sci style toggles...
