My Pork Barrel WAS working ... FIXED!
Started by brucer, May 10, 2014, 05:05:53 AM
brucer
Please help this lowly novice:
I built myself a Pork Barrel.
It worked on my testing rig, then I tried to put it in my too small first etched enclosure (urgh!).
Now it no longer works in the testing rig! (tested it while waiting for a bigger enclosure to arrive, urrrgggh!)
I measured the following voltages:
IC1 (JRC4558D)
1: 4.54
2: 4.54
3: 4.47
4: 0
5: 4.51
6: 4.54
7: 4.54
8: 9.2
IC2 (TL062)
1: 1.7-7.6
2: 4.52-4.64
3: 3.17-5.99
4: 0
5: 4.52.4.63
6: 3.24
7: 3.27-5.82
8: 9.2
IC3 (MN3101)
1: 6.82
2: 0
3: 0
4: 6.8
5: 6.74
6: 0
7: 5.95
8: 0.45
IC4 (MN3007)
1: 6.87
2: 6.83
3: 3.78
4: 0.45
5: 0
6: 0
7: 5.97
8: 5.32
Q1:
C: 9.18
B: 2.55
E: 3.44
Q2:
C: 9.18
B: 3.88
E: 3.78
Q3:
C: 9.88
B: 3.11
E: 3.55
Q4:
C: 5.09
B: 0.63
E: 0
Q5:
C: 6.0
B: 2.7-4.8
E: 6.8
Does anything stand out?  Something solvable?  Any assistance would be appreciated.  I liked the effect when it worked!
Thanks!
twin1965
Boxing it up probably disturbed some wiring or bad solder joint. If it was working before then this is what you need to be looking for.
Do a visual check of the wiring and also check for continuity. Check all the solder joints and see if any are loose or if the solder looks dull and not shiny. Best thing is to reflow all the joints. If there was a cold solder joint then this normally fixes it.
If this doesn't work then you'll need to audio probe the circuit to see where the signal stops and start your troubleshooting from there.
rullywowr
Are you using solid or stranded wire?  Solid may break inside the insulation. Also as mentioned try reflowing all the joints. Get it working on the testing rig again first.  I'm sure you can nail it!
brucer
You were right guys.  Thanks!  I did some solder re-flows on the pot leads and now the chorus works fine.  I'd built my own PCB mount pots from solder lug pots and jumper wires.  I guess they got jostled a fair bit when I tried to fit the board in a too small enclosure (I was trying to fit a 3PRR board in too).  :-[  Live and learn.  Thanks again.
twin1965
Glad you got it working :)
rullywowr
Excellent work!  If it worked before you boxed it...it couldn't be too far off the mark. :)
