"always on" pedal wiring diagram?
Started by thesameage, May 09, 2014, 03:02:26 PM
thesameage
Does anyone have a diagram for wiring a pedal as "always on"? I'm making a THC headphone amp and just want it to be on when I plug the cables/power in. No need for a switch. I wouldn't mind hooking up an LED, too, though.
Just connect the fx input to the input jack and the fx output to the output jack. couldn't be more simple. If you want an LED, just tie it directly to ground and it will light when the power supply is connected.
thesameage
Thank you! I figured it had to be something simple like that.
