Switching Ideas for multi Fx pedal
Started by the3secondrule, April 29, 2014, 11:46:55 PM
the3secondrule
Hey guys, I'm getting set to build my ultimate dirt box for bass.
I pretty much always have at least 2 out of BMP, RAT, Hotcake, and Klon on my pedalboard, so I thought I might as well just build a crazy 4-in-1.
Just trying to wrap my head around what sort of switching scheme I want to use.
I definitely like Thomas H's Ultimate switch with the radio button style (selecting one effect turns of the others). But I also like stacking my dirt. I'm also pretty keen to have a single master switch for all the dirt.
So probably just looking at wiring 3pdt, for each effect, with a master on/off. but thought i'd see if there were other options to consider.
Cheers
J
It is possible to use toggle switches to make Thomas' system and both/and option. For instance, you could set it up so that you can have all four switches as independant on/off bypass, or have 1-4 switches that turn off the others that might be on.
