recommended wire gauge for common projects
Started by Vintageman, April 27, 2014, 01:26:07 AM
Vintageman
Sorry for such a silly qwestion, but...what´s the wire gauge that you use for the most usual fx projects. Is there one that´s the most suitable?
Talking about simple projects (with no shielded wire or other singularities)
Thanks, best regards.
I think all my wire is 24 gauge, and I like it that way. I think some others use 22, but I wouldn't go smaller than 24.
electrosonic
Smallbear #24 Prebond - Really easy to work with and nice quality. I won't use anything else now.
http://www.smallbearelec.com/servlet/Detail?no=903
Andrew.
Quote from: electrosonic on April 27, 2014, 01:54:49 AM
Andrew.
Seconded. This is my favorite wire.
Vintageman
Thanks buddies.
I read somewhere "increasing gauge numbers denote decreasing wire diameters" So 22 gauge is wider than 24 gauge...(and maybe could be better?)
Am I right?
Thanks again.
Yes on the number thing - smaller number means larger wire. Wider does not necessarily equal better.
Quote from: lincolnic on April 27, 2014, 03:24:01 AM
Andrew.
Thirded.  I wish they hadn't gone to a thicker jacket, but it's still my preferred wire.
Chromesphere's wire is also pretty decent -- it has more of a flexible feel to it, like fine sewing thread, whereas SB's #24 feels more solidcore.
Quote from: alanp on April 27, 2014, 05:55:08 PM
Chromesphere's wire is fantastic, I've got bunches. Bought it about 3 times, kept forgetting I had it. Barry's hook up wire is killer also. It's more like pre bonded than solid core. It was especially helpful on my massive build.
Clayford
I use 22g and love it. 24g I tend to tear up.
Prebond is the shit, but I can't always get it, and so I stay away from it.
Home Depot sells some 22/4 wire by the foot. It's jacketed, shielded, and has a bare ground wire.
$0.33/ft Red Green White Black.
Pure copper.
Love it.
head solder jockey, part time cook: cranky&jaded
Quote from: pickdropper on April 27, 2014, 06:50:29 AM
Andrew.
FOURTHED!! (Quartered?)
chromesphere
Hey, good to hear feedback about the wire guys!  I know what I like, but wire is so personal...its nice to see its working out for others as well!  Here's a link for anyone that hasn't seen it:
http://www.diyguitarpedals.com.au/shop/index.php?main_page=index&cPath=7
I'd also recommend salvaging wire.  I used to get loads of wire this way.  Unfortunately though its limited quantity and color.  So you find perfect AWG wire with the right jacket rigidity and 2-4 colors but when your out you have to start looking again...bit of a pita.  Still worth while looking around your house you might find a stash of good stuff :D
Paul
das234
I like the prebond 24g but I bought a bunch of 22g from Tayda (cheap!) that I'm working my way through.  It's fine but it's a tight fit in some holes (hush, Jimi!) and I generally have to tin it before I solder it up.  When I'm out, I'll probably stick to the prebond stuff.
+1 For Smallerbear #24
Haven't tried Pauls yet, maybe next though?
