Low Current LEDs (and power saving)
Started by rullywowr, April 10, 2014, 05:29:33 PM
rullywowr
Just curious if any of you use/used to use/swear by/dislike "Low Current LEDs?"  Mostly for LED indicators in pedals.  Also wondering if they may "sound" different to your ears when used in a clipping circuit?  The ones I came across here have a fV of about 1.9v.
These are about 0.20c a pop at Mouser and draw 2mA.  2mcd brightness (typ).
http://www.mouser.com/ProductDetail/Vishay/TLLR4401/?qs=%2fha2pyFaduhWRCNY2UVIVjQcNqusW51tP1yt1W7WiKc%3d
The bulk of vanilla LEDs I have come across in the past consume somewhere around 20mA.  My focus of the week is reducing power consumption with various methods and just stumbled across these.  It's not a huge deal when running off an adapter but I have been working on reducing power usage for battery powered circuits.  These may have their place...
That's neat. How do they compare in brightness? In the real world, not on a datasheet.
I just use regular high brightness LED's, dare i say Tayda's, and they usually only require much less then 1ma to be bright enough for me, so 10k-18k for a current limiting resistor...  have some greens that were fine with ~50k. I only use led's for visual reference. I visually test each led for it's needed CLR.
rullywowr
Quote from: midwayfair on April 10, 2014, 05:52:46 PM
That's what I was wondering!   :D
Quote from: davent on April 10, 2014, 05:56:13 PM
That's good info Dave.  I always find myself taming the brightness of LEDs.  I wonder the difference between the "low current" and using "high brightness" with a larger CLR?  Also wondering how the low current versions sound in led clipping circuits like the Boneyard/Plexitone/Plexidrive etc...  Perhaps there is no difference, but only one way to find out!
Mark Hammer's idea for an LED tester, switch puts another 10k resistor in series so 24 steps, pretty much covers them all.
