MOD - LDO
Started by tazidore, May 26, 2010, 07:46:28 PM
tazidore
Hi !
Great idea to create a separate layout for the Landgraff MoD.
I would appreciate much if you could do the same with Landgraff LDO.  ;)
Thanks for sharing !
Best regards.
Try it, it doesn't hurt.
pandadandan
Quote from: tazidore on May 26, 2010, 07:46:28 PM
Hi !
Best regards.
Couldn't you just use one of the other Tubescreamer-style circuits and use the different values?
tazidore
I heard it was a kind of 808 on steroids... But did not look much closer. Your idea is interesting and I'm gonig to have a look right now .  ;)
A regular TS with an external diode switch is all you need. On/off/On - 1n914's/nothing/RED Leds
tazidore
#4
So few parts change in there (+ diodes/led switch.)
Not used to do it (beginner), but I'm going to try modding 808's pcb to fit those leds and build a LDO clone.
Really easy, the GGG one already includes diodes/led switching ! Have to include one cap, change three values, redraw PCB, job quite done. If anyone interested ...
Thanks for your advice, and for sharing.  :)
