Gibson Maestro Fuzz Tone
Started by PhiloB, April 04, 2014, 03:27:59 AM
PhiloB
Buddy of mine has a Maestro Fuzz -1A, meaning it runs on (1) AA battery.  He wants to be able to plug a standard 9v adapter to power it.  Could I use the Road Rage to convert the power to appropriate -9V and then use the Beavis Audio dying battery simulator to get to the 1.5V needed ?
http://www.beavisaudio.com/Projects/DBS/#Adding
Is there a better way to drop the voltage to 1.5V?
Have you thought about suggesting building him a Maestro clone that you can use a road rage or other voltage divider to get down to 1.5V? Rather than mod a really cool old vintage unit, it might be easier to build a new version in a 1590B for him.
Clayford
THis and then some. You really don't want to modify that circuit at all. And AA's are so filthy cheap....
head solder jockey, part time cook: cranky&jaded
PhiloB
I questioned him on wanting to modify this unit.  He's talking about removing the hard wired cable as well.  He mentioned not liking the tone (losing a lot of low end).  This might be a good point to argue for building a clone and changing the filtering cap.
Clayford
Quote from: PhiloB on April 04, 2014, 03:40:37 AM
Yes please.
http://www.ebay.com/itm/Original-Gibson-Maestro-Fuzz-Tone-F-1A-Pedal-/261439708685
http://www.ebay.com/itm/Gibson-Maestro-FZ-1A-Fuzz-Tone-Guitar-Effects-Pedal-Original-Fuzztone-FZ1A-/171284446800
I don't think he realizes exactly what that thing is worth.
PhiloB
His isn't nearly as pristine but you make a great argument none the less $$$
Clayford
http://experimentalistsanonymous.com/diy/Schematics/Fuzz%20and%20Fuzzy%20Noisemakers/Maestro%20FZ-1%20and%20FZ-1a.GIF
Here.
Make him two.
Voltage divider to get 1.5v
9v
Z (500k)
   --------- 1.5v
Z (100k)
GND
use a 1M and 500k for the 3v Version.
He'll thank you later.
If he doesn't like the tone...
Sell it and build him something he does like!
PhiloB
I left him a message before bed last night and woke up to question about a clone.  Sounds like he's entertaining it.  I'm thinking he wanted to have that pedal on his board, for conversation sake maybe.  I shared the eBay listings$.  It'd be hard to argue with that.
So to drop the voltage would be a matter of fixed resistors?  Next question would be, which would be a 'better' choice? 3v or 1.5v?  3V for more headroom;)
You guys have been a real help, thanks!
Timbo did one that runs on a power supply if you can find it. It was probably a year ago.
Here's the link to that thread:
http://www.madbeanpedals.com/forum/index.php?topic=11500.0
But most importantly:
So this uses 1n914's to get the voltage down to -1.5vdc from the charge pump and it was the best way I could find to do it after a lot of breadboarding.
PhiloB
PhiloB
Hey Timbo, I didn't see the vero layout referenced in the other thread.  Do you still have that available?
