DPDT switch wiring
Started by AntKnee, April 03, 2014, 07:33:20 PM
AntKnee
I'm building the buffered bypass version of the simplified centaur from tagboard. Find it here:
http://tagboardeffects.blogspot.com/2012/03/klon-centaur-bare-bones.html?showComment=1396552192981#c3522234994566461261.
I'm a bit confused by the diagram. I'm trying to wire this up, but don't know what to do with "Output Jack & Sw5" and "Volume 2 and Sw6". Do I put two wires in the board, or go to the jack and then the switch, or the switch and then the jack? There are two wires to Sw4, do they both go to the switch lug? Do any jumpers go on the switch? Just need some help wiring the switch altogether. This is my first vero attempt and first use of DPDT switch.
Thanks for the help!
Naa, go from the board to the output jack and then another wire from output jack to sw5. It will be easier because the output jack has more room for 2 wires. And the same for volume 2 to sw6. The lugs on the pot are big enough for 2 wires as well. This should make for neater wiring as opposed to running 2 wires off of the vero board.
AntKnee
Quote from: jimilee on April 03, 2014, 07:41:26 PM
Dude, Thank You!!!!!
What about the Sw4 part, just take the two wires and put them on the switch?
Quote from: AntKnee on April 03, 2014, 07:54:46 PM
yes
