Kraken doesn't kwak - FIXXED
Started by fixxe, March 31, 2014, 07:04:16 PM
fixxe
I got bypass and a normal guitar signal when engaged...what do?
I took some pics, but somehow they came out darker than expected. Should I take new ones, or read voltages first?
Thanks!
Build quality is sloppy...sorry
Edit: Holy shit, that camera brings out the worst in my soldering skills!
Voltages could help. Have you seen the 'rules for debugging' thread?
fixxe
Quote from: jkokura on March 31, 2014, 07:08:04 PM
I have, but it's been a while. Let me check...
fixxe
Oh, and I wasn't to sure about the orientation about that one IC without the cutout
fixxe
oh and Q2 needs to be flipped 180°, but the build document says it works either way, so I di not try that yet.
fixxe
Quote from: fixxe on March 31, 2014, 07:19:01 PM
The IC is correct now. If you put it in there backwards the first time, it may be fried.
fixxe
Quote from: jimilee on March 31, 2014, 08:37:52 PM
Yes, that's how I put it in the first time
Pin 1 of IC 1 shouldn't have 0 voltage check for bridges and or a bad socket. Also, is there anything between that pot and the pcb?
fixxe
So NC doesn't mean Not Connected or No Current?
NC would stand for 'Normally Connected'
NO stands for 'Normally Open'
In the case of what the OP is asking....
The "NC" on pins 1 and 8 of the CA3080 mean NOT CONNECTED.
NC means Normally Connected when you are referring to SWITCHES.
DOH!
Yes, context is everything, and I didn't double check.
fixxe
fixxe
Does anyone have the voltages for the transistors?
