variable voltage mod to obtain lower voltages?
Started by danwelsh, March 30, 2014, 08:23:26 PM
danwelsh
Hi guys, just had a brain fart and wondering if anyone has tried this or would it even work.....as everyone knows some pedals sound good with a dying battery, on the side i build variable voltage ecigarettes so i got to thinking whynot use the vv regulator and wire it between the power source of the pedal and add in a pot to control how much voltage gets through, it wouldn't overpower it because the main power source would only output what ps you're using...would this work i wonder or just create noise in the circuit? It'd be nice to see the voltage with a voltage display.....but i've tried just adding a voltage display when breadboarding a circuit and that causes noise.....
just put a 10k pot in series with the +9v line....
danwelsh
Quote from: LaceSensor on March 30, 2014, 08:35:47 PM
wow, i was overthinking that one....lol
Quote from: LaceSensor on March 30, 2014, 10:44:16 PM
Check this yo
http://www.beavisaudio.com/Projects/DBS/
Or use a LM317 variable voltage regulator setup if you don't want to introduce current reduction as a byproduct of series resistance...
Clayford
Quote from: danwelsh on March 30, 2014, 08:23:26 PM
[...] on the side i build variable voltage ecigarettes so i got to thinking... [...]
Mods are cool - Prefer a variable wattage myself.
Quote from: LaceSensor on March 30, 2014, 10:47:26 PM
Check this yo
This is what I was going to say. The series pot also reduces current, which may or may not be beneficial in any given application.
