Loophole pedal problem
Started by ross3030, March 15, 2014, 10:49:30 PM
ross3030
Hello everybody. My Loophole is working well except one major issue. I am not able to play over the playback signal. When I turn ON the pedal I hear my guitar while playing, after pressing RECORD switch I play the loop passage and finish recording by pressing the switch again. Then I press the PLAY switch to play back the recorded loop BUT I can not play over it. Is there any solution to this issue? Thanks a lot.
Lochybicknell
I have this problem as well. Any pointers?
Make sure Dry is turned up. If it's down, then you're never going to get anything.
Check the parts in the Dry signal path (C3-5, R5-7).
