State variable filter preamp
Started by garfo, March 06, 2014, 01:21:16 PM
garfo
That is precisely it.No, there is absolutely no need for a selector when I have the Blend Pot.It does what the selector switch does, plus more.I'm using a Bourns MN taper blend pot.It shous almost no resistence at the center.Much better than the other Blend pots where I would always find a volume loss and tone sucking at center position.
RobA
I forgot about the blend when I was thinking about how you have this set up. There are a couple of ways to use the blend pots. There's one that replaces the toggle and goes into a volume. But, there's another way to do it that leaves them more independent and still uses the toggle. It essentially works out to be like the standard Gibson LP circuit, but with both volume pots replaced by the blend pot. I have the Bourns blend on one of my guitars now using the first type of circuit, but I'm going to be moving it to the second and putting the toggle back in.
Since you are going to be putting some resistive elements after the SVF's, I don't think you will need or want the 10k to ground. The 10µF cap is probably going to be bigger than you need, but it won't hurt. You could probably replace it with a 1µF film cap though. You do need a cap there though on the outputs of each of the SVF's.
The JFET buffer looks like a good choice for the output. Since you don't need the high input impedance of the JFET, the BJT version of the same circuit might actually be a bit better of a choice, but the JFET should be fine.
garfo
What is the bjt version???Sorry for my ignorance  ::)
kothoma
The one with the Si-NPN Transistor...
garfo
because it has a lower impedance input!?I could build it with the 2n5088.Or is there a better silicon choice!?
kothoma
Yes, mainly because of the lower R1/R2.
A 2n5088 is a good choice, as is a BC549C/BC549B/BC550 (turned 180°). Or a MPAS18.
garfo
I've wired it as it is in a box.Works fine, will build the second svf with precision resistors, will try 064 and 074 opamps and decide for one before I decide to build it as you suggested with another ic making the bias.
garfo
Well, by the way, What values in terms of pots should I use.For Blend I can get 250k and 500k only, but what about volume pot.Should I go with 500k or should I go under that with this build in mind as it is!?
RobA
Quote from: garfo on March 07, 2014, 01:49:19 PM
It depends a bit on which blend circuit you are using with the MN pot. One of the circuits I've seen commonly used effectively halves the impedance of the pot, so the 250k ends up looking like a 125k to the output of the previous stage. That's still going to be OK here really because you have the active buffers from the SVT, but you do want to match your volume pot to be about the same level as the impedance from the blend circuit. If you are using this circuit with the 250k MN pot, then I'd think that a typical 100kA volume pot would be a good choice.
I do wish that Bourns would come out with some 50k and 25k versions of the blend pots to use with active pickups.
The other reason the BJT version of the output buffer is a better choice than the JFET version is that BJT's typically have better current drive than JFET's. This allows them to better overcome the capacitive load that the guitar cable puts on the signal.
garfo
#24
Yeah, i know, ideally we should keep impedance low when mixing the two signals, and I could do that latter on, and a smaller value mn taper blend pot would be great.Unfortunately they only have those two.
I'm using a 500k Bourns Blend Pot, and at the moment I actually have a CTS 500k volume pot that I was intending to use here(It's the one on my bass).Also, I have wired the blend pot leaving the ground connection off, don't know how that affects impedance, but it works passively on my bass.
So,impedance wise, if I use the 500k blend, should I go 250k on the volume and then buffer it!? :P
I'm curious about this because I'm not sure how this specific pot will interact with the volume.
Wouldn't it be 250k only when at center position?I believe that these pots in particular due to its taper have a different interaction, correct me if I'm wrong.
RobA
I take it that you are doing the wiring method like the way I currently have it in my guitar since you mention leaving off the ground connection. (I do have the ground connection on mine.) I'd have to think about what leaving off the ground does impedance wise in the circuit. But, when the ground connection is in place, the resistance from signal to ground is 250k for the 500k MN pot no matter what the position of the pot is. It's a bit weird, but it happens because of the way two sections are interconnected. You can just measure the resistance with a DMM with the jumpers in place to see what it is on the way you have it wired.
After saying all that, it would be more ideal if you could match the low output impedances of the active electronics, but I doubt if it is going to cause you a great deal of problem if you can't. I guess I'd try to use the 500K pot you have and see how it goes. If it causes any tone loss issues, you could always buffer the blend output with a transistor buffer stage like the output buffer you have planned. You could get both buffers and the volume pot on one small board if you needed to.
garfo
For now I will be doing the blend/master volume passively and only buffer the output.If I wire the ground of the blend and end up using a 250k volume pot at least they would be matching and the output buffer would see that load which would more or less match it's input load.
I will get together with a friend that has more experience designing boards and we will together try to develop this a bit further, but for now it's just me and I'll use what I have.
Nevertheless all the suggestions here are awesome and I'll try to use some of those ideas.
garfo
If I leave the 3.3k resistor as it is and change only the cap to lets say 12n I can get a minimum of 248.84hz and a max of 4019.06khz.It goes a bit lower, and the highs play in a better ball park for the bass.
Quote from: kothoma on March 06, 2014, 05:05:10 PM
Quote from: garfo on March 06, 2014, 04:30:06 PM
Is it not possible to shift Only the lower frquencies?
Quote from: kothoma on March 06, 2014, 04:03:49 PM
As the frequency is determined by 1/(2 pi R C) with R=R8=R9 and C=C4=C5 you can halve the frequencies by doubling either the values of C or R. Using C4=C5=22n should shift the frequency range to 136Hz...2.2kHz.
Oops, need to be make a little correction: R=P2+R8=P3+R9, of course.
Using 50k+3k3 and 10nF as in the schematic:
R=53.3*10^3 and C=10*10^-9 gives 298.6Hz
R=3.3*10^3 and C=10*10^-9 gives 4823Hz
Using 50k+1k5 and 22nF for example:
R=51.1*10^3 and C=22*10^-9 gives 140.5Hz
R=1.5*10^3 and C=22*10^-9 gives 4823Hz
You should get the idea...
But now your freq pot could be a bit harder to dial in as it now sweeps over 5 octaves instead of 4.
kothoma
Quote from: garfo on March 08, 2014, 10:51:03 AM
Right, then the range shifts (down) by a factor of 10/12.
garfo
#29
I just remembered that I have a CTS 250k Volume pot that I've scrapped the final taper and it offers infinite resistance(No Load), maybe I could use it after the blend pot, in those terms the load before the last buffer would be The blend's Load.
I took the measurements of the 500k Blend pot and it is as you say, around 230k load.
Quote from: RobA on March 08, 2014, 02:04:43 AM
