Dragon Breath (1590A Unicorn Breath and Crackle Not Okay)
Started by Ettore_M, March 05, 2014, 07:28:32 PM
Ettore_M
Not as much as it sounds ("Dragon Breath"  ::) ), but it's a great tool for a pedalboard, due to both its size and sound.
It's a 1590A combo of a Crackle Not Okay (a layout of mine and I had it already built) and 1776 Effects' Unicorn Breath. The latter is a buffer board and is a new project from Josh, that will be available in the short future.  ;)
The Unicorn Breath gives a little more clarity to the sound, but it's completely transparent!
Sounds amazing and I think it's a great combo!  :)
Outside: Copper paint and no lettering. Simple as possible!  ;)
Inside:
The input jack goes to a DPDT switch which is the bypass for the buffer (if you ever don't want to use it) and then to the Crackle Not Okay board and the output jack.
Wiring on this was pretty simple, because most of the wiring is already done on the board.  ;D
Hope you like it as much as I do!  :)
Hector
- Culturejam
Ettore_M
- Culturejam
