I am so over.... Stranded Wire
Started by playpunk, March 02, 2014, 09:30:38 PM
Quote from: muddyfox on March 04, 2014, 03:59:00 PM
Quote from: LaceSensor on March 04, 2014, 01:37:19 PM
I use this
http://www.guitarpcb.com/apps/webstore/products/show/2249043
Its the bollocks. But quite pricey.
Same here. Best I can buy for the money...
sent from my mobile device
Has anyone compared this to the bonded that small bear sells? How is it better? I like getting the SB #24 on 50' spools for $5. I think it's perfect and it would probably take something with unicorn tears in it or something to get me to upgrade.
Quote from: Leevibe on March 04, 2014, 04:18:27 PM
I use this
I have both and like SB #24 better. That being said, GPCB is fine it's just a little too thin for my taste. That being said, GPCB wire might be better for people that do super tight fits. I haven't had any issues with either.
Quote from: lincolnic on March 04, 2014, 05:09:40 AM
Can you elaborate a bit more on your chopstick method? That sounds pretty handy and I'm always trying to neaten my wiring.
Basically I pin one end of the wire against the side of the enclosure with one chopstick and make a nice 90 degree turn using the other chopstick  to sort of pinch the 90 into the wire on the outside edge of the turn so to speak.  Then I'll keep the chopstick in place and burnish the wire so it doesn't have any little waviness where it runs along the enclosure side, make another 90 back away from the side to the switch or whatever.
Maybe I can shoot a little time lapse final wiring of a pedal...
muddyfox
Quote from: timbo_93631 on March 05, 2014, 06:20:00 AM
How does this work on tight builds?
And I can't say I can fully picture the process, if you could film it it'd be great!
Thanks! That makes sense to me, but it'd probably be fun to see a time lapse anyway.
I'd be keen to see a video if you have the time.
Neat wiring is not something that comes easy for me. It's one thing I really dread when comes time to box.
