WTF was I planing on putting in this case?
Started by midwayfair, February 19, 2014, 06:52:03 PM
I have a white 1590B that I drilled for four pots and either a second LED or a toggle.
I've only had the case for a couple months and I can't figure out what the heck I was planning on putting into it.
jimmybjj
I saw in a previous thread (I think :) ) you were building a zen with a buffer switch, that would fit the description.
Pcbs no longer available
DutchMF
My first thought was a Mudbunny with a fourth pot (pick whichever you want) and a P19-style switch, but after some consideration, that's not really you.... Could it be a Cardinal with something extra?
Paul
Jabulani Jonny
#3
Thank you for the next submission for the meme thread!
Jonathan
Quote from: jimmybjj on February 19, 2014, 06:54:47 PM
I converted my mini zen to buffered input/buffered bypass ... that was a while before I bought this case. I'm not really the kind of guy to put a buffer on a switch, since buffered bypass doesn't make a difference in my setup.
heh, Thanks, JJ.
Paul: I did consider that, but I'm not sure what I'd add to a cardinal ...
aballen
Timmy pedal with a clipper switch?  Maybe a stage fright, which has two leds?
Actually, I figured it out. It was a 5-knob overdrive that I ended up deciding to use a different color and wanted. The lower row of knobs was supposed to be offset but I think I also didn't like that idea.
Unfortunately, I can't tell anyone what the pedal was, because it's a secret! oooh, mysterious!
