Rissole PIF
Started by Droogie, February 10, 2014, 07:57:45 PM
Droogie
Got this from Alan P as my first ever PIF! Went together easily, even boxing wasn't too tough with all the switches and whatnot (despite a dodgy jack from Tayda, hence the mismatch). The box is Candy Teal from PPP—not sure what to do for labels yet. Still have to tweak the rate LED a bit.
It sounds great and there are a lot of possibilities with this: from funky envelope, cocked wah, and burbling madness—and I love the blend pot.  Great project!
Chief Executive Officer in Charge of Burrito Redistribution at Hytone Electric
LaceSensor
Aw man you didnt do the loop. Well worth it! :) but nice anyway.
Do you get any collisions with the chicken heads set up like that?
https://www.gigaheartsfx.com
instagram @gigahearts_fx
Droogie
#2
I had to adjust the knobs pretty exactly to avoid collisions. Was going to do the loop but my jack supply was too low-- and I really didn't want to wait too long to try this one out. The Lovetone addiction might be spreading! Looking forward to the Doppleganger when that gets going.
That is really, really nice! Don't fib, btw, it's a bugger getting any Meatball board to fit, with six pots and four switches, but it's worse with this one, with the LEDs and the added switch!  ;)  ;D
If you're able to fit them above the four top pots like I did, I strongly recommend putting the loop and expression jacks in. The Intensity jack is really, really neat :)
(And I'll own up to the knobs having issues with fitment... squeezing 10 knobs in such a small space comes with unique issues.)
Sweet! Can't wait to give mine a go
Droogie
Quote from: alanp on February 11, 2014, 03:58:26 AM
...it's a bugger getting any Meatball board to fit, with six pots and four switches, but it's worse with this one, with the LEDs and the added switch!
The one thing that was tricky was dealing with the height of the toggle and rotaries copared to the pots--might be easier with longer right angle pots. Thanks for the pif and the project!
LaceSensor
Quote from: Droogie on February 10, 2014, 11:17:20 PM
The Lovepedal addiction might be spreading!
Ewwwww
Lovetone
dont confuse the divine with such heathens
Droogie
Fixed.  :-[  just don't make build a Ring Stinger on vero as penance!
muddyfox
So in preparation for my Rissole build, how do you folks approach boxing this thing?
Do you first drill the box, fix pots in there and then lower the board on the exposed pins (this seems impossible) or do you solder pots to the board and bend and twist them to conform to the existing holes (also seems rather impossible with all the rotaries)?
quick question...What is a PIF?
Droogie
Quote from: muddyfox on February 11, 2014, 02:53:54 PM
Soldered all pots and switches, then rocked funked that thing first  8). I overdrilled the holes for the rotaries, pots, and toggle a bit to allow for some play due to typically less than perfect drilling. A little filing to tweak and bingo. Still have to redo the LED.
Having done a Nautilus before was good learning experience for this.
PIF is the "Pay It Forward" contests from December.
blearyeyes
CHICKEN FIGHT!
That looks really cool!
LaceSensor
Ive built a few meatballs
the best way is to get a drill template, double triple quadruple check it, then mark and drill the box
oversize the holes by 0.5cm (or whatever that is in yank)
screw the rotaries to the box, and the (hopefully board mount style pots)
Lower the pcb into the enclosure, and wiggle all the pins in.
You may find doing just the rotaries first easier, then the pots second. Never the other way round as the rotaries sit higher than standard board mount pots.
I use liberal blu tac to ensure the board is level, perpendicular etc (OCD as you wish)
Then solder, natch
good luck
I wouldnt try to solder first drill later, thats asking for issues of fit in my experience
I soldered first, and took advantage of the fact that even pcbmount pot legs have wiggle in 'em. Once you've got a turn or so of thread through to the face of the enclosure, you can put the nut on and use that to pull the rest of the pot through.
LaceSensor
Quote from: alanp on February 12, 2014, 04:19:26 AM
This'll work but I don't like the idea of the extra stress on the joints.
Especially true of the plastic rotary.
