Rissole PIF
Started by Droogie, February 10, 2014, 07:57:45 PM
muddyfox
Good thing I asked!  ::)
wiggling pins into the board has been a nightmare for me already on a few 4-pot 1590B builds, I can't even imagine wiggling four rotaries in and then the switch and then the pots too. I guess I better overdrill generously!  ;D
Right now I'm considering not putting in the boardmounted pots at all but making them out of regular solderlug ones and some diode clipoffs, that'd make them a whole lot more "wiggleable" or "insertable" if I solder them to the board first?
Thanks!
Bump for a drill template for this beast
This particular build is the 1.0, the 1.4 has a different arrangement of controls -- the drills are the same, but the control placement is not.
The first page of the build doc should have a roughly 1:1 pots, LEDs, and switches layout -- print it out and compare it to your PCB to see if it is scaled correctly.
Quote from: jimilee on April 19, 2015, 03:00:19 PM
Jimi I was working on one. Here is the basic layout if it will work for you. Let me know if you have any questions buddy.
http://music.codydeschenes.com/wp-content/uploads/2015/04/Rissole-1790NS.pdf
