Constant sorrow: i need advise:P
Started by Gledison, February 09, 2014, 11:56:14 AM
Gledison
Guys!
The solution was easy!:P
Removing the bloody plastic caps from the pots solved the case!
Thanks for the help and the good tips!!!
Clayford
I assume you put some tape on the back of the pots to prevent shorting?
Thomas_H
Quote from: Gledison on February 09, 2014, 12:34:55 PM
Hey mate.
Im located in Mannheim, close to Heidelberg.
Recently I'm ordering from Banzai. Sometimes i order from Tayda but takes 3 to 4 weeks to arrive, plus the lottery with the customs!:S
Just to let you know: reichelt has low profile caps a well as musikding.
DIY-PCBs and projects:
Gledison
Quote from: Clayford on February 09, 2014, 08:06:36 PM
Yes mate! i've added a double layer of tape on the back of each pot...and it worked just fine!
Cheers
Gledison
Quote from: Thomas_H on February 09, 2014, 08:17:22 PM
Hey mate.
Thanks Thomas. i've never heard about this shop...:S
Good tip!
I think I built about 4-5 1590a before I discovered low profile electros, I feel your pain
chromesphere
#21
Its for this reason I pretty much only ever use low profile caps now.  One less factor to worry about ;)
