Dual Function
Started by pickdropper, February 07, 2014, 02:18:56 PM
Stomptown
Great job Dave! I love the grid you used in the graphics. Very fitting for an f(x) build!
Very impressive, as usual. I was going to do ours as a Ffx triple but am now considering sticking the fuzzes into a 1590A. Purely because I can.
Quote from: juansolo on February 07, 2014, 07:55:18 PM
That's what I did.  I like the fuzzes in a 1590a with a toggle switch to choose which effect is active.
jimijam
doesn't get much cleaner than that. the etch looks fantastic. a design of that type is so difficult 'cause any variation in the pattern sticks out like a sore thump,but you really pulled it off wonderfully.
tried lifting weights once....they were too heavy!
Quote from: pickdropper on February 07, 2014, 08:06:02 PM
Indeedy. We've got it down to two knobs and a switch :) (bit of dual gang wafer swappage). Have to admit that Cleggy did the boards though. I tried but I couldn't see the resistors  :'(
Quote from: juansolo on February 07, 2014, 08:52:53 PM
That's a cool approach to the knobs.
Sometimes it is an advantage to keep them separate.  I usually set the two fuzzes differently, so I like being able to toggle between them without having to twiddle the controls.
that is one fine build. Wasn't expecting anything else when I saw your name as the author. What is the 4th knob on the grease gun? Pot instead of R7? what is that changing?
hoodoo
Quote from: m-Kresol on February 07, 2014, 09:27:11 PM
If you read Brian's build doc , it's an optional resistor that knocks down the bass a bit.  By turning it up, the bass comes back (and the gain seems to increase a touch as well).  I put it in the experiment with, but so far I think it sounds best stock.
Looks great Dave! How's it sound?
Quote from: jimilee on February 08, 2014, 05:08:41 AM
It sounds really good, actually.  I like the low gain drive of the GreaseGun quite a bit.  I could see it being very useful on a pedalboard.  I like the vibe, too.  I prefer the LFO on the sine to the choppy with this one.  I also think there is a slight treble roll-off with a drive pedal pushing it.  I noticed it with the GreaseGun and with a Klon.  I might tweak things a bit, but I like it even without any changes.
This etch, I can't even.
You've outdone yourself!
Amazing build. That grid graphic leave no room for error.
Hexjibber
Great build and an awesome design and etch as usual! :)
