Modded Biyang RV-8 Reverb
Started by PhiloB, February 01, 2014, 04:44:01 AM
PhiloB
Picked it up for $20.  Really decent sound when in the vintage mode.  Problem was there was a significant volume drop.  Built up a EHX LPB-1 with trimmer on vero and with the help of fine folks here, have it running at unity!  Stoked that I can access the trimpot through the battery compartment, you know, in case I want to crank the volume and use the pedal for a cavernous solo or some other nutty business.  This would be my first mod to a factory pedal.
Dont forget us when you're rich and famous!!!
billstein
Nice one Philo. Way to work that out. :)
RobA
Nice. Any chance at identifying the IC's on there? I can't make out the markings for them on the photo.
PhiloB
It would take a magnifying glass.  I couldn't make it out with my naked eye.  Used to have awesome eyesight, now I'm 40.
RobA
You're still young compared to me. I have to use one of those 10x magnification loupes to read some of those SMD parts.
I'm wondering though since there is a crystal on the board. I'll look and see if I can find a high mag photo of the board online somewhere.
AllenM
PhiloB
Rob, in my brief searching I couldn't find anything!  Let me know if you come across something.  There is a A/B switch and A sounds like crap, it'd be nice to figure out what's going on there.
RobA
Will do. How do you like the pedal overall?
PhiloB
I don't have a lot of reverb experience other than amp spring reverb.  If kept in the 'B', it's very nice, especially 'Spring' setting.  Worth the $20 for sure.  But my needs aren't extensive when it comes to reverb.  Once I have my favorite setting the knobs probable won't get moved much.  It is pretty versatile with the 'Blend' and 'Time' Knobs.
RobA
Hmm, if I can't figure out what they are doing with a web search, I may just have to pick one up. Thanks for the info.
PhiloB
There is also a Tri-Verb (RV-10).  Looks like the same circuit in a smaller enclosure.
RobA
Quote from: PhiloB on February 01, 2014, 04:42:20 PM
Ah, that's the hint I needed. It looks to be based around this processor,
http://www.wavefrontsemi.com/index.php?id=11,14,0,0,1,0
PhiloB
RobA
Quote from: PhiloB on February 01, 2014, 05:39:33 PM
So there is untapped effects?
Could be. It depends on how Biyang programmed it or if they modified the code on it at all. It might even be possible to reprogram it yourself if they've put the programing connections on the board. I'm doubting that though since it would add to the cost and wouldn't do anything for their sales/marketing.  The chip itself though certainly has more algorithms on it and the possibility of programing other algorithms.
