schoon toon explanation
Started by Kipper4, January 29, 2014, 02:55:31 PM
Kipper4
I've seen the Schoon Toon here and the build doc but I'm affraid I dont understand the schematic could some one throw some light on it please.
inputs?
outputs?
power supply?
Stumped :)
heres the build doc. I hope its ok to post it
http://f.cl.ly/items/442Q1k1k3F1r30352q2T/Schoon%20Toon%20Doc.pdf
It's a blend knob for effects that lack one. Ideal for bass players.
It's a bit of an 'advanced user' item.
Effects use a bypass switch. This is a circuit for having a bypass switch and a clean blend with whatever circuit you build. The control pot "knob" will pan between the effect and the bypass signal.
Kipper4
i see so its all wired to the switch.
I understand a little better now thanks for the reply.
I'll try to wrap my head around it and see what i come up with.
