Road Rage Help
Started by MullisMan, March 11, 2011, 11:49:26 PM
MullisMan
I'm trying to deliver 18v to a Timmy Pedal using the schematic from the road rage, with a few components left out. I'm installing it inside the enclosure I housed the Timmy in.  Problem is, i'm not getting 18v from the 18v output, i'm only getting 9 volts.  I've included the schematic and layout i'm using for my board, I made my own layout without the -9v output and the regulated output.  Any help would be greatly appreciated.
[attachment deleted by admin]
MullisMan
Would that be C2 on my schematic or C2 in the schematic from your project files?  :)
In yours. It is not needed for what you are doing. I'm not sure if that is causing the problem, but it will at least eliminate one possibility.
