IS there an Afterlife? Sure there is in a new convenient size!!!
Started by jimilee, January 20, 2014, 07:45:00 PM
This is my very first successful 1590A pedal build. The Afterlife compressor is a very quiet squishy pedal. It's very impressive. I built it in what was originally going to be a headphone amp, but that didn't work out. For me, compressors are an a;ways on effect, so that's why I decided to build it sans the stomp. I've always wanted to build one without it and voila!!
That's a very good start to your new 1590a addiction, Jimi.   ;D
Quote from: pickdropper on January 20, 2014, 07:58:02 PM
You know what's next? Tube screamer!  :P
rullywowr
Verah nice!  Doing anything in a 1590a is always a special challenge.
Quote from: jimilee on January 20, 2014, 07:59:32 PM
3 pots and 3 switches, baby.
Quote from: pickdropper on January 20, 2014, 08:09:51 PM
Maybe I'll get a little better at it first....
Quote from: jimilee on January 20, 2014, 08:13:59 PM
Honestly, you don't need to put all (or any of the switches in).  I tend to like the clipping switch and set the bass cap where I want it.  I don't use the treble switch as much so that is the first one I leave off.
I have also put the bass switch as an internal jumper option.  That worked fine.
It really is a bit of a hassle fitting three knobs and three switches in there.  I am not really in a hurry to do it again soon.
neve1272
that graphic is really cool jimi good idea about the switch too
that whole 1590a thing is pain i will never be able to inflict on my self i struggle enough already
Kip
Please...Please...Please....
Put some heatshrink on the connection between the LED and the 9V supply  :-\
One little knock of the pedal and it is smoke city  :o
danwelsh
That's a cool build man....I extremely like your sans switch idea. And thanks for that tip about the LED/9v  Lacky
Clayford
I love your LED grounding method!  Did you use the Vactec, Marcon, or roll your own LDR?
head solder jockey, part time cook: cranky&jaded
Quote from: Govmnt_Lacky on January 20, 2014, 11:39:35 PM
Good point, didn't notice that.
Quote from: danwelsh on January 24, 2014, 03:13:57 AM
Thank you, running another wire seemed pointless and this was so obvious, and with the cover on, it won't move. I did this with the klone I built and can't find also. I used a vactrol, vtl5c3 I be
I've is what's in the Bom. This compressor is very quiet, I am surprised at how quiet it is.
Gledison
congrats for the first 1590a.
i've just bought an enclosure and started slowly to think what will be the first build on it!!!
still scary!!!
:S
