Nautilus
Started by Megadeth, January 18, 2014, 09:01:15 PM
Megadeth
Here is some pictures and a small video sample. It is much more extreme then what the camera actually picks up. This thing is a beast and it got hundres of setting. I find the gainpot quite sensitive and will experiment with that one in the near future.
I had a grounding issue on my board. Tried to fix the traces with my exacto but it didnt work out in the end. So i and ended up cutting the traces leading the the HI/LOW switch and wiring the switch to the other components and moved the input directly to the gainpot and Voila! it works like a charm.
Still have to get my drill and expand the holes for the jacks since i originally used metal jacks but replaced them with plastic. Awesome pedal all in all and i do not regret building it.
http://imgur.com/so3FEYt,gvQZ63O#1
sirbergersworth
Sounds great. I have been sitting on a GGG board for a year or two. Really need to build it.
Sent using Tapatalk
"Comes a time when the blind man takes your hand, says, "Don't you see?"
-Robert Hunter
