Voxy
Started by Droogie, January 18, 2014, 03:53:25 PM
Droogie
Here's a build on Jubal's excellent Voxy Brown board. Went together easily (with an assist from the wiring diagram found in a thread here). Overdrilled one of the LED holes a bit so I had to improvise a fix using a couple of nuts.
I'm really digging this one—there is a lot of interaction of the tone controls—and more tones than I was expecting. With the boost off, it will totally clean up at a decent volume. Boost on does what you would hope a pedal based on a Vox would do! Really nice circuit and layout!
rullywowr
That looks great!  I have one of those boards I need to populate.
If this one does clean, I think I'll have to build it :) Hopefully it will look as clean as yours does! (My ROG English Channel will NOT do clean. At all.)
Good work!
Droogie
It does clean with Tele pups, that much I'm sure of. I haven't hit it with buckers yet.
Nice job. I dig it!
The wiring can be a bit tricky. I should really add the diagram to the build docs.
Droogie
fendman
Hey you did a great job on this pedal, like the way you did a different orientation of the board. Yes the off board wiring confused me but I got there..The graphics are great to :)
Cheers
Mike
