rangemaster etching layout with radial caps
Started by Gledison, January 15, 2014, 02:38:36 PM
Gledison
Hello everyone,
on the pdf file for the ragemaster it says:
"All of the caps have extra pads so that you can use either axial or radial type capacitors. The lead spacing for the radial
pads is 5mm for film, and 2.5mm for electrolytic. For axial film, the spacing is about 18mm. For axial electrolytic it is
20mm."
looking to the ready to etch layout there is no pads for the radial caps.
Does someone have the etching layout with the extra pads?
thanks in advance
Gledison
