Looking for amp simulator pedals
Started by wretched, January 01, 2014, 09:52:42 PM
wretched
Does anyone know of any good amp sim pedal clones? I think Joyo makes a few. I already have something for tweed.
Like the chunk chunk? I believe bean also has an ac30 too.
wretched
Yep like the Chunk Chunk. I am just putting that one together now hope to have it going after the weekend. As for the AC30, is that the "daytripper" ?
wretched
I see Tech 21 made a few. I ended up getting BlackBird and Plexi Drive PCB boards. I also have a Tweedy Bird and Professor Tweed in the works
Any one know of any others?
Quote from: wretched on January 03, 2014, 07:41:12 PM
Almost everything by Runoff Groove is at least good. But for now, build the Azabache and Supreaux Deux for low-gain type stuff, and the Thor for higher gain. Thomas_H has PCBs for a bunch of ROG circuits
wretched
Thanks I grabbed all 3. This should keep me busy for a while.
wretched
First off GREAT demos, I looked these PCBs up on YouTube.  I am getting ready to place an order and wondering if a 20k Trimmer would be okay in place of the 25k trimmers the Thor and Azabache are asking for?
Quote from: wretched on January 08, 2014, 04:36:48 PM
"Most likely."
FETs are like delicate little snowflakes, and the biasing can be precise in Runoff Groove builds. However, there is a bell curve to the expected drain values required to properly bias the FETs. Runoff Groove's design philosophy indicates that one should use a trim pot twice the size of the expected value when building with FETzer valves. If you're building with a J201, you can expect the drain value to be a touch over 10K -- which means a 20K will actually get pretty close right in the dead center, but some super incredible outlier could require a larger trim pot. In other words, 20K is just fine for the Azabache for sure, but I thought you'd like to know the why of it. :)
I can't speak regarding the Thor, I haven't built that one, only breadboarded it. Marshalls just aren't my thing.
wretched
a little off topic, but could I use a trim pot in place of a resistor on a board. I have read that I could just use the middle and one ends as a lead. I only ask because I have to Bias some j201's for some other builds that I have been putting off. If this would work I could build the circuit and then use the trim pot to find the resistor I need.
Quote from: wretched on January 08, 2014, 05:26:35 PM
Yes, of course. But most builds with FETs use trimpots unless the biasing isn't critical.
wretched
They are a couple from Chi Boy The tweedy and Black Bird from the looks of them they are great, but I have to sort through the j201s I picked up from SmallBear.
aeroemi
Quote from: midwayfair on January 03, 2014, 07:45:06 PM
... Cool... Where could i get the Thor schematic?
Sent from my Lumia 800 using Tapatalk
kothoma
Quote from: aeroemi on January 09, 2014, 08:29:20 AM
google
http://www.runoffgroove.com/thor.html
(and also build instructions for http://diy.thcustom.com/shop/rog-thor-modified-v1-2-pcb/ )
