Current Lover D4 clarification (again)
Started by das234, December 22, 2013, 10:28:26 PM
das234
I know this has been asked before but I want to make sure I get it right.  MN3207 version of Current Lover, D4 is soldered to a pad between D5 and C6.  Is that INSTEAD of its normal hole?  Or does it get connected in its normal hole and then jumpered to the D5/C6 junction?
Your answer lies on Sheet 5 of the build doc.
Good Luck!  ;)
das234
Ok.  Maybe this will make it clearer.  Should it D4 get installed normally and then a jumper added like this?:
Or should I ignore the normal pads and install it directly from D4 to D5/C6 like this?:
The right way is the second diagram you have posted...
das234
