GGG Triangle Muff
Started by mct, December 14, 2013, 02:59:39 AM
mct
Finished this build the other week. Kind of launched me on the path that I'm now taking, ending up here and in the DIY section at ILF. Nothing fancy here, just proud that it looks semi-clean and works. And damn does it sound good. I was stoked it was the muff I was looking for  8)
Hail to the king, baby.
125B?
Builds with battery snaps always make me feel faintly guilty :)
Nice looking work!
Stomptown
Looks great!  :o I wish my first build looked that clean.
One thing to point out is that the black wire you have connecting the 1/4" jack sleeves (ground on each) is unnecessary. They are already connected to each other through the aluminum enclosure. As long as one of the sleeves is grounded the circuit (PCB and 3PDT) you are good to go! Unless you are using a plastic closed frame 1/4" jack (which your not). FYI, Madbean has an amazing standardized wiring diagram available on their projects page that is worth its weight in gold! I would definitely check it out when you get a chance.
Cheers,
Jon
wretched
Looks great. I love me some Muffage!! What does the top look like ?
Diamond
Nice! I really love my GGG Triangle. After trying many different transistors, the most regular, common, standard 2N3904's sounded best in mine. They gave the most clarity and tightness, if that's what you're after. Where did you get the red switch?
mct
1. Pretty sure it's 125B, I'm not too familiar w/ my enclosures yet.
2. Good looks on the grounding, I'll have to try taking that out
3. The top is plain. Just the metal enclosure w/ some simple knobs
4. The red switch came w/ the GGG kit.
Very nicely done. Looking forward to seeing more builds from you. The one pedal that has NEVER left my board over the years is some sort of Big Muff. Its my go to pedal. I suggest cranking it up and pissing off the neighbors then build another one. Rinse and repeat.
