What is This Called??
Started by TreeSlayer, December 07, 2013, 01:07:13 AM
TreeSlayer
I need to get a replacement for this. what type of connector is this called? thanks a million in advance!
Layton
http://i53.photobucket.com/albums/g61/TreeSlayer/th_2013-12-06185411_zps8c42fbee.jpg?t=1386381251
"At the line it's just you, me and the tree." the TreeSlayer
"You have the rest of your life to make excuses and be a fuckin' pussy. Today is your day OFF!"  Amiri King
croquet hoop
#1
IEC connector?
There are many variants (pin layout), so be careful when you choose the replacement.
edit: looks like what you need is the C14 variant http://en.wikipedia.org/wiki/IEC_connector#Appliance_Coupler_standard_sheets
rullywowr
Yup, it's an IEC.  If you can wait then order it online for about $6.00 otherwise Radio Shack will gladly sell you one for about double that.
TreeSlayer
wow! that was quick! y'all reckon Mouser would have it?
croquet hoop
TreeSlayer
Quote from: croquet hoop on December 07, 2013, 01:16:30 AM
Sure. For instance: http://fr.mouser.com/ProductDetail/Kobiconn/161-R301B07-E/?qs=sGAEpiMZZMv1TUPJeFpwbhNb2LLV2zw6wEih7O7UrUE%3d
(just check the datashet to be sure, but it should be okay)
thanks a million, Matt!! you're a life saver. if there's anything I can do for you, just holler!!
Layton aka the "TreeSlayer"
croquet hoop
What are you building, and do we need to build one also?
TreeSlayer
Quote from: jimilee on December 07, 2013, 01:49:34 AM
LOL! actually, i'm rebuilding an old, cheap amp that one of my co workers was given. it's a transistor type. I have two tube amps, and actually this thing has a tone all it's own. it sounds cheap, but it might have a place. you ever seen one of these?
http://i53.photobucket.com/albums/g61/TreeSlayer/2013-12-06205711_zps355fd0ae.jpg
Quote from: TreeSlayer on December 07, 2013, 03:32:15 AM
No I haven't, but it looks most interesting.
TreeSlayer
It is. All I have left to do is replace the plug and finish up some of the other wiring and hope for the best! I'll post some audio later.
Quote from: TreeSlayer on December 07, 2013, 03:57:04 AM
Good luck sir, them things will fry and take you along with it. Be careful!
TreeSlayer
Will do, ole Bud. I know these things ain't no pedal! I've been very careful and double triple checking behind myself. Thanks for the concern. Take care! I hope the bad weather we've been getting doesn't make it to your neck of the woods!
Quote from: TreeSlayer on December 07, 2013, 04:15:00 AM
Nope, weather went North of us and just left a little bit of rain.
TreeSlayer
Cool deal Bubba!
