Everybody need a pair of.......
Started by GrindCustoms, December 03, 2013, 12:25:10 PM
GrindCustoms
BoobTubes!  ;D
Full picstory.
Bare drilled.
Gold Bricks!
Renegadrian 6.66 VoltageMultiplier / Klonish Output Buffer / Heaters Vreg
Hardware in.
The Implants.
Ground Bus Wiring Done.
Partially Populated.
PSU remaining.
Succesfully Implanted.
The Outside.
mcalaff
hoodoo
Let those no mojo mofos  on that other thread get a look at these pair of mojoriffic boob tubes, very cool. I can't believe you distressed that beautiful gold finish  though  Rej ;)
wolfingsworth
That wiring is very very impressive! Well done!
slimtriggers
Holy Wow! Outstanding. I don't know what's up with the contests, but you should definitely enter this if you can.
It's cool to watch how much better your work has gotten Rej. Not that it was ever bad persay, but that work up there is really good. Keep it up.
icecycle66
When are you going to slather the guts with epoxy?
PSU we're using for the next one ;) Built and tested. Needs two heatsinks and runs the HV at 190V (going higher isn't recommended). Runs two 12AX7s no trouble.
As no one bought the Marshall pedal I had up for sale, it's being rebuilt currently  ;D  It's going to be the definitive BT Twin. We've done one before with lots of options on it (to see what was worth doing), this'll be the stripped down end version in theory. Really good and way better than the original Twin.
Also, you really need to build the pentode one. It's rather good and quite a bit different.
Looks like a junglegym in there... in a good way. Awesome wire job! Can I ask what you used to get that cool bevel on your drill holes? It really looks clean.
rullywowr
Extremely clean wiring, and tons of mojo caps for that great toan.  Thanks for sharing your build pics...pretty inspiring!
Gledison
This build should have a link to the ongoing mojo thread!👌😛
evildead222
