Potentiometer Question
Started by evildead222, December 02, 2013, 10:18:37 PM
evildead222
How do I turn a 500k linear pot into a 250k linear.  Can i use a resistor.
Gledison
#1
Just add. A 500k in parallel u get the 250k! 1/Rt=1/R1+1/R2
Add the resistor between lugs 1 and 3!
Cheers
evildead222
i connect the outer lugs with a resistor?
Gledison
Yep! Sorry, ive just updated my answer
muddyfox
yes but will it still be a linear pot?
Gledison
Gledison
I would sugest you to get the right pot , but if you cant, try it with the resistor and see how it goes! You can always change afterwards
evildead222
yea it's just to test it out then i'll order the right pots
DutchMF
I hate to disagree with Gledison, but it's a bit more complicated than that. To start with, it depends on how the pot functions in the circuit, is it a voltage devider, variable resistance etc... This is some good reading: http://www.geofex.com/article_folders/potsecrets/potscret.htm
Getting the right pot is always preferable, but to start: a linear pot with a resistor bootstrapped over it will never remain linear.
Paul
muddyfox
Quote from: DutchMF on December 03, 2013, 11:52:42 AM
Yeah I had a gut feeling about that when I asked... I really should take time and read "Life of pots"...  ::)
DutchMF
It's really difficult to get your head around stuff like this, if I say so myself. I made an Excel sheet once, with some graphs linked to all the data, to visualize what happens when you start messing with pots and resistors, but I lost that one......... If I get really bored, I will give it another go, because it worked fantastic!
Paul
I agree Paul however, I would be pretty confident saying that it will get you where you want to be  ;D
It would be close enough to a linear taper that it would work. If you want perfection.... then get the 250KB pot. If you want it to work NOW, use the 500KB pot with a 500K (or 510K) resistor strapped between Lugs 1 and 3.
A small sacrifice for having it completed now.  8)
DutchMF
Quote from: Govmnt_Lacky on December 03, 2013, 12:40:33 PM
Yeah, you can certainly do this to see everything works, but when the pot is used as a variable resistor, like the gain control in the Egodriver, this won't work......... Sorry for being an ass, I really only try to help.  :D
Paul
Quote from: DutchMF on December 03, 2013, 12:46:39 PM
Paul
Why do you say that? Connect lugs 2 and 3 and it's two resistors of 500K = 250K.
DutchMF
If you have a variable resistor pot, putting a resistor across lugs 1 and 3 wont work, was what I meant........ Or am I completely mistaken? At work at the moment, so no time to double check. If I'm wrong about this, I'm sorry and will delete the mis-information.......
Paul
