Noob Zombii Q2 and Q3 transistor question
Started by ridgeback, February 27, 2011, 05:34:04 PM
ridgeback
For the Zombii, can I use the "Continental" Fuzz Face PNP transistor pair from Small Bear parts?  The pair has a OC75 and OC76 each at a gain of 89 and 105 respectively.
If they will work, these transistors don't have tabs but they both have a red dot on the side that I assume indicates the collector lead.  Is this correct?  The multi-tester check seems to confirm this.
Finally, on the Zombii PCB regarding Q2 and Q3, which are the collector, base and emitter connections?  Perhaps for clarification, looking at the PCB, the Q2 and Q3 connections are both in a "V" shape with round connections at the left and mid point  of the "V" and a square connection at the right.
Thanks very much.
