SMD LEDs
Started by muddyfox, November 27, 2013, 01:20:51 PM
muddyfox
So... still dipping my toes into SMD waters, I was wondering whether there was any difference to using LEDs as clipping diodes when it comes to SMD vs TH?
Other than SMDs being a tad harder to socket and experiment?  :)
croquet hoop
As long as the forward voltage is the same, they shouldn't be different.
muddyfox
Is there perhaps a folk-wisdom kind of a blanket statement out there that goes something like "all red LEDs are created (almost) equal" or "most of the time red LED is a red LED, whatever the package"?
My SMD LEDs are still on a slow boat so I can't really measure, I was just wondering whether there's some sort of general consensus as to the real life LEDs' FVD...
croquet hoop
#3
What gives a LED its color is the type of semiconductor used. So, different semiconductor, different electrical properties. Same color, regardless of the package = similar properties.
http://en.wikipedia.org/wiki/Light-emitting_diode#Colors_and_materials
kothoma
#4
Quote from: muddyfox on November 27, 2013, 03:06:42 PM
Yes. Compared to regular 3mm and 5mm LEDs there's just less plastic and wire, the semiconductor is the same.
But then there's MOJO VOODOO, so you never know.
muddyfox
excellent! thanks fellas!
now to find some with sik tonez...
I believe the diffused LEDs are almost all the same inside. It's the water-clear LEDs that vary widely in forward voltage.
muddyfox
ha, I was actually just wondering about that because it would appear that smd leds also come in different versions. i have some led strips labelled as 5050 and have no idea on the specs of the ones coming in from china. i guess i'll check the voltage anyways when they get here.
chromesphere
Good question muddy! I wouldnt hessitate using them. Also would be interesting to using them with a light plate, probably in strips?
