1/2 watt resistors
Started by jimilee, November 18, 2013, 05:36:50 PM
So if you're at all like me, sometimes you don't pay attention and order 1/2 watt resistors. Well my collection seems to be growing. What can I do with these big ol resistors?
rullywowr
You could make a layout on vero with 'teh mojo tonez' from the 1/2w resistors!
croquet hoop
Make a boost or an overdrive, and post it over at TGP stating how these resistors give increased headroom.
Quote from: croquet hoop on November 18, 2013, 05:52:51 PM
Can someone please send the maid over to cubical 2 to clean the coffee off my monitor?
Gledison
Maybe a Neckless for your girl?
heehhe
If the board isn't tightly packed, you can just use them as standing resistors.
Most of the resistors in the preamp of a tube amp are 1/2-watt.
depending on values, I'll take them off your hands.
Also, the companion fuzz is designed to accept 1/2 watts.
Quote from: culturejam on November 18, 2013, 06:05:22 PM
I guess you'll just have to build a tube amp.  With a built in phaser.
Quote from: jkokura on November 18, 2013, 06:27:03 PM
I will check tonight.
Quote from: Gledison on November 18, 2013, 06:03:03 PM
heehhe
bwahahahahahaha your an necklace? Neckless is way different :-)
Gledison
Quote from: jimilee on November 18, 2013, 07:32:08 PM
heehhe
Damn it!
Bloody english!
Ettore_M
+1 ! What CJ said!  ;)
Hector
- Culturejam
