Your suggestions for etching projects
Started by madbean, November 15, 2013, 02:15:20 AM
blackedition
Okay, I don't have a lot of confidence in getting a good layout for the OC-2. At least not an etching layout. However, I think I could make it into a fabbed 1590B board if there is any interest. It would be a nice alternative to the Low Rider. Two lower octaves in a smaller box.
blackedition
I'd certainly be interested in an OC-2 board!  It is a pretty sweet pedal!
icecycle66
How about the EHX octave multiplexer?
And doesn't Taylor offer an OC-2 PCB? Or has his shop shut up.
pietro_moog
what about some analog delay with 4 3208, maybe modulation, fitting in a 125B? maybe even without modulation.
Taylor does have the "Chopped OC-2", I believe. I was thinking of doing the full circuit. Main difference is input/output stages from what I saw. So, it wouldn't be copying his project. Think it is too close, though?
Quote from: madbean on January 08, 2014, 04:09:41 PM
I think the input and output is the same and all it's doing is dropping the two octaves down section...
He no longer has it listed as a project though and you're doing the whole thing rather than cut down, so, why not :)
I don't know if the chopped version or octave multiplexer would be etchable though.
And while of no interest to me, there is always the classic Blue Box.
blackedition
Full OC-2 is the way to go in my opinion!  I want both octaves! :)
artstomp
..is B.K.Butler tube driver on the list?
PimpMyTone
My suggestions : the vintage mxr enveloppe filter  an the DOD fx20 phaser .
Simon
artstomp
...and another transparent overdrive..the MAXON OD820...!!!!
pedalman
How about some reverb tank thing. I know bean wont touch tubes, but im sure he could conjure up something.
Maybe something low voltage with a pump
pietro_moog
what about a ds1 with board mounting pots?
