Your suggestions for etching projects
Started by madbean, November 15, 2013, 02:15:20 AM
As I mentioned here, I'm redesigning a lot of the old etching projects to bring them up to my current standards. However, this doesn't have to be limited to things I've done. What are some projects you etchers would like to see available? Make some suggestions and they just might happen. I'm feeling over-confident :)
EHX POG, Digitech Whammy, Boss RV-5 and Frank Zappa's discography.
I Kiid.
artstomp
..the green bean would be fun for newbies..
Gledison
Maybe some difficult flanger!
Whatever you add i think all the junkies here will build  anyway! :-/
Cheers Brian
wolfingsworth
You have such an awesome library of etchables already! I guess I will second the Green Bean and maybe a Rangemaster that has a little less Mojo would be cool.
DutchMF
We should get Haberdasher in on this discussion! I mean, he etches for all of us who don't want to get in on that stuff ourselves....... But...... I think a lot of people would like to see the old 2-channel Boneyard, and a lot of the stuff that's based on a well known boutique fx company that uses a lot of BS170 transistors.... There used to be a lot of that stuff around here. Also, the one box that brought me to this place (and I never built!!!!), the MI Audio Crunchbox!
Paul
I've just realised that I'm at a very odd place where there are no effects I actually want/need... It's peculiar and I'm sure I'll snap out of it shortly.
rullywowr
Quote from: juansolo on November 15, 2013, 10:37:40 PM
You sure you are feeling OK? :)
icecycle66
Daughter boards, daughter boards, all the daughter boards!
A madbean 3pdt.
A board for combining two 3008 chips to make a 3005
A wet/dry mix that can be added to various MB boards
Tap tempo board
Some sort of board that can hook up with the effect circuit so that you can use a momentary switch to rapidly engage and disengage the effect.
Splitter boards we can use to put a selection of options (like different trannies or diodes) that we can wire to the circuit board and increase our clipping options and what not.
Other things like this that I don't even know about.
Also vertical layouts for kokbox etc, like the stub I was done for the zombie.
icecycle66
That deadastronaut reverb chrome sphere has been pimping.
Would love to see a 1590a flanger or phase 90!  ;-)
Have plans to do some smd versions that should fit the bill as soon as work slows down a bit
ggarms
spaceboss
Maybe some EQD stuff: Hummingbird/ Vox Repeat Percussion would be a rad pedal--especially if there was a way to accentuate or control some of the ring-moddish qualities.
I am addicted to etching. Its my favorite part of the build... well next to playing with the pedal. I am so excited that you are wanting to make more etchable layouts for us etchers. Thanks so much Brian.
Quote from: icecycle66 on November 16, 2013, 12:05:44 AM
A madbean 3pdt.
Tap tempo board
+1
and a few others on my mind
OpAmp BMP
Green Bean
Univox SuperFuzz
Test Rig of some sorts
Dont know if it has been mentioned yet but...... this would be INCREDIBLY useful....
A de-facto drop in adapter board to use the MN3007 chip in place of the SAD1024. As compact as possible  ;)
I know they have been done but, something readily available would make repairs and projects using the SAD chip much easier!  8)
