Tonepad CE-2 clock noise
Started by gtangas, November 07, 2013, 01:24:08 AM
gtangas
gtangas
YESSSSSS
solved... This as a bastard circuit...
As I started the post in was having clock noise with this circuit. When I tested it I could hear the noise but it was outside the box and... I box it and tic tic...
I shielded all the cables and a shield sheet that I in an broken equipment between the pots and the Pcb... Noise again...
Today i took it a part again and flip the Pcb shortening the wires length and did the input and output grounding wiring... Problem solved
I hallways use Brian key for the footswitch that honestly I never care for the others keys..
A big shout for Scruffie...
brejna
Gilmourisgod
I had the same problem with a Byoc analog chorus, solved by wiring input jack tip to #4 lug on 3pdt stomp switch with shielded wire.
